pparks1
It's too cold to go outside and look, but if my understanding is correct I will need a T40 torx and a T25 torx to completely remove the belly pan from my 2013 Passat TDI, right?
From what I have seen online, there are 3 of the T40's along the back of the engine, and then another 7 of the T25's with 2 on the passenger side, 2 along the front and 3 along the drivers side...all on the bottom, right?
My '02 Passat was more of a hassle with those little half turn speed fasteners and those little clips that would always fall out, not to mention having to have the short stubby screw drivers in the wheel wells.
It seems that the newer Passat is more of a straight bolt up to the bottom of the car.
