Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old August 23rd, 2018, 22:08   #31
nwdiver
Fuel Economy: 320wh/mi; ~90mpge
Originally Posted by gearheadgrrrl View Post
You 'lectric car fanboys have forgotten how little power a solar array puts out and how much it takes to charge an electric dependent car. Real cost of solar is around $15/watt after figuring capacity factor, so the typical "sized to the tax write off" home system will give you about a kilowatt. That means after a couple days of sunny weather you'll manage a recharge, assuming your solar array survived. Takes a TDI owner about 10 minutes to pour a couple of 5 gallon cans of diesel in the tank and we're good for another 400 miles!
With a good pro install that's ~$0.065/kWh over 20 years on average. Since an EV gets >3 miles/kWh that's <$0.022/mile. If you're crafty you can DIY your solar array and save >60% lowering the cost per mile to <$0.01/mile; An ICE getting ~50mpg with diesel at $3/gal is ~$0.06/mile. Pretty much no matter how you slice it a solar powered EV is significantly cheaper to fuel than a diesel powered TDI...
For daily charging speed is irrelevant. I've only pulled into my driveway with <20% battery a handful of times. Plug in daily and don't worry My 10.7kW array produces ~45kWh/day so I'll be set for whatever I need...
nwdiver is offline   Reply With Quote
Old August 24th, 2018, 06:22   #32
compu_85
Gadget Guy
compu_85's Avatar
Originally Posted by nwdiver View Post
...Since an EV gets >3 miles/kWh that's <$0.022/mile.... An ICE getting ~50mpg with diesel at $3/gal is ~$0.06/mile. Pretty much no matter how you slice it a solar powered EV is significantly cheaper to fuel than a diesel powered TDI...
Our Passat cost about $0.08/mile. Because our super cheap off peak electricity it costs about $0.02/mile to drive the Fiat and $0.03 to drive the ELR.
And like you said... the electron tank fills up while we sleep, and is ready when we leave in the morning The ELR has a "be charged by" feature, so it will finish about 45 minutes before I head out for work.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old August 24th, 2018, 07:44   #33
Good Ol' Boy
VeeDubTDI's Avatar
Originally Posted by turbobrick240 View Post
You're really just revealing your ignorance regarding photovoltaic systems. They come in all sizes and capacities. Their up front costs get amortized over a useful life of 25+ years. The og tdi crowd was all about efficiency. Hard to beat the efficiency of photovoltaics and EV's. Like it or not, it's the future.
I couldn't agree more. Well said.
Old August 30th, 2018, 14:39   #34
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
My TDI cost me $4000 back in 2003. If I can get an EV and a solar array for around that price, I'd be up for it. Maybe tack on an extra $2000 for inflation.
Jetta SS is offline   Reply With Quote
Old August 30th, 2018, 14:51   #35
turbobrick240
turbobrick240's Avatar
That's not a very fair way to think of cost of ownership unless all of the fuel you've burned was free. Plus oil changes, timing belts, etc..
turbobrick240 is online now   Reply With Quote
Old August 31st, 2018, 22:22   #36
nwdiver
Yep... O&M would have cost me ~$12k with my Jetta over the last ~5 years especially since it was due for another EGR cooler / valve But I guess if you never drive your car his point is valid... but then what's the point of having a car?
Old September 1st, 2018, 05:57   #37
tikal
Fuel Economy: 37 MPG (~ 45% city)
I can envision TDIClub members (and non-members) in the next few years having both an EV and a light duty diesel vehicle in their garages. Problem solved for city driving, highway driving and emergency evacuation driving
tikal is offline   Reply With Quote
Old September 1st, 2018, 15:46   #38
nwdiver
What's the light duty diesel for?
Old September 2nd, 2018, 06:29   #39
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
For when your sitting on the side of the road with a dead EV battery....
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 2nd, 2018, 08:59   #40
john.jackson9213
TDI(s): 1996 B4V
That is one of the reasons I leased a 2018 Chevrolet Volt, extended range of the on board generator.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old September 2nd, 2018, 09:57   #41
nwdiver
The car does an incredible job of preventing that now. The car calculates how much charge you need to make it where you're going; If you're not gonna make your destination the car will tell you to slow down. Anyone that depletes their battery these days pretty much did it intentionally...
Old September 2nd, 2018, 19:30   #42
gearheadgrrrl
Fuel Economy: Other than the JSW, hard as I try, can't seem tio get below 40 MPH!
The efficiency is there, the problem is the cost.
GearHeadGrrrl
gearheadgrrrl is offline   Reply With Quote
Old September 2nd, 2018, 19:52   #43
oldhifi
oldhifi's Avatar
Where I work there are several cars plugged in....pretty cool
oldhifi is offline   Reply With Quote
Old September 2nd, 2018, 20:34   #44
tikal
In my field of work I consider it 'unlike redundancy' form of transportation.
Old September 3rd, 2018, 12:00   #45
nwdiver
Do you own an EV for 'unlike redundancy'?
VW Site "Electrify America" El Dobro General VW Discussion 2 December 15th, 2016 17:33
New VW commercial Bobmws VW Passat Family (NMS and B7) TDIs (2012+) 8 August 15th, 2014 08:33
VW Commercial NewTdi TDI 101 8 June 11th, 2014 13:46
ANOTHER New VW Commercial El Dobro General VW Discussion 16 June 2nd, 2006 13:24
VW Commercial lumberjackbob General VW Discussion 2 May 27th, 2005 23:45
Page generated in 0.16341 seconds with 11 queries
[Output: 133.51 Kb. compressed to 112.32 Kb. by saving 21.20 Kb. (15.88%)]
