Hello all,
My first post with TDIClub.
Bought a 2005 Passat GLS station wagon with the BHW / B5 engine with 175K miles late August, now at 177K. Previous owner had a lot of work done on it by dealers so took a chance it would be in good shape. Maintenance records show:
- 142K timing belt, tensioner, water pump, thermostat, fan clutch
- 167K new tranny
- 171K EGR valve, mass air meter, replaced cylinder head & cam shaft (salvage parts), fuel filter, both manifold gaskets, new turbo, oil change.
- ???K front suspension, brakes.
Last night, just noticed a 2" spot of oil on the floor. Had not noticed any leaks before. Added 1/2 Qt 505.01 to top off.
Not familiar with this engine yet, but leak appears to be coming from near front bottom of the engine where there's a horizontal gasket split about 4''/9.5cm from the bottom of the engine. And, I can feel some oil above that gasket split. (I tried to insert a photo, but just got pages of alpha-numeric gibberish when I previewed my post.)
Can someone advise me what this might be? Hope to gawsh it ain't the dreaded balance shaft module or oil pump. No weird noises coming from the engine--but I'm not familiar with TDI's and they make more noise that the typical gas engine. A mechanic who checked it out before purchase had no comment about this oil leak, so I presume it has just started.
Thanks!
KurtsTDI
- 167K new tranny
Thanks!
KurtsTDI
