kompressorvr6
- Joined
- Feb 19, 2005
- TDI
- TDI PD115 / 2000 / Black
I'm stuck on this one! I have a PD 115 Golf and above 2k rpm the car eventually pulls fine with full power however when I start off in each gear and try to pull away more than gently the car stammers and chugs before becoming smooth.
The car has just reached 120,000 miles and had the timing belt replaced today along with the tensioner and damper. I did not expect this to cure the fault, but it was due.
In what order, and which things should I check to fix this, I am used to loads of low down torque and the car's peak torque around 2k revs and it's been taken away from me! So far I have used Vag-Com to test the solenoid valves but am I right in saying that this cannot confirm alone if I have a vacumn leak in one of the small pipes at the back
Lastly, the EGR valve has started weeping oil, I have taped up both holes just under the diapham, it's hard to tell if the fault appeared before of after these leaks though.
All advice will be much appreciated.
Thank you in advance with regards Jamie, UK
