KLXD
If you're looking at the instructions on this site the last step on adjusting is a little off but the only removal is the timing belt cover.
You loosen the three bolts and rotate the pump shaft CW to advance.
And don't rotate the engine using the cam or pump. Only rotate with a wrench on the crank.
