And, removing the motor mount bracket is sort of like working a puzzle. You need the ability to manipulate the engine (up, down, back, forth, etc.) to work the bracket out. Sometimes you can get lucky and it seems like it just falls out... same with going back together. Also, those are Yield To Torque bolts ... thus it is sort of a PITA to access with a torque wrench....
As stated, tweaking the timing with VCDS generally doesn't take long......... the engine must be at or above 85c for the info in the Graph to be correct. Once the Graph is showing the Timing, the mechanic shuts down the engine and loosens the three bolts on the IP sprocket enough to move the pump shaft ever so slightly (Clockwise > advance, counterclockwise > retard). And, an experienced mechanic/guru will be able to hit the sweet spot on the first or second attempt (or it might already be in that sweet spot). (Obviously, the bolts are re-tightened once the adjustment(s) is made.)
As I alluded to in my first post, your TB and all of the components involved, are on borrowed time and miles .......... like almost 50% over! I wouldn't be driving it if it were mine...
