T-watts
I tested my MAF a few days ago with VCDS and it showed that it was bad. Punched it in 4th gear at around 2000 rpm up to over 3000 rpm. MAF requested was in the 800s but MAF actual was in the 500s. It would sometimes go to 700 but quickly trail off.
I replaced the MAF with the new style from metalmanparts.com. Same result. Power did not increase, so I hooked up VCDS and go the same readings as with the old MAF.
I checked the wire harness and was getting 12V between pins 2/3 and 5V between 3/4. Air filter isn't new, but I blew it out with air. It is a little soiled but not bad.
Any Ideas?
Any Ideas?
