Hidden marinco behind license plate
Loved this thread, and it got me thinking. Didn't want to see the plug on the car. So decided to put it behind the license plate.
BIG Shout out to PeterV for helping me with this at his house. Heated garages are the best!!!!
I have an aftermarket bumper -oettinger, but I think the process would be rather similar for a stock bumper. Car is an 03 Jetta tdi.
Take the license plate and bracket off, in my case I had to get bumper off first to get to the screws holding the bracket.
Put the bumper back on, and use the license plate holes as a reference to mark on the crash bumper metal ( I used a drill to do this).
This will tell you roughly how to center the plug, and also where it has to go in relation to the bracket holes to the bumper.
You can then cut the hole in the crash bumper:
You can see the frostheater cord inside the bumper - bumper is hollow
Next cut a hole in the bumper. Check twice or four times, to get the right spot. These two holes need to align!
Install the marinco ; in this case I added a pig tail plug to the marinco, so that I can disconnect the bumper from the car easily. Using this 1 foot cord from stayonline -
http://www.stayonline.com/detail.aspx?id=28519 cutting it up a bit, some dielectric grease and quick disconnect here you go!
Re-assemble the bumper to the car, remember to plug in the marinco!
Plate folded down, installed this way so if the spring breaks the plate will still hide the marinco and show the plate. The concept of failing "safe", safe in this case is license plate visible, and marinco shielded from the road.
Plate up ready to access the marinco. The marinco was installed so that if I forget to push the cap back in, it will cover the plug connections by default.
Plugged in and heating!
I am still torn about the install of the flip up, since you can see the hinges, but its not overly obvious. Installing with the hinges down would have hidden it even more, but when (not not if) the spring breaks the license plate would flop down and cause me more work to repair etc. This way, even if the spring breaks, the license plate is properly visible and marinco is still hidden.
