Old December 7th, 2017, 10:04   #31
jagster936
Sounds interesting, subscribing
2002 Silver Golf TDI, 5sp., 117k miles, dynoed 163 WHP, VNT17 turbo, Malone Stg 4, PP764 Injectors, 3bar MAP, SB stg.2 clutch - by AARodriguez
jagster936 is offline   Reply With Quote
Old December 7th, 2017, 19:57   #32
UhOh
UhOh's Avatar
Originally Posted by ihredneck View Post
I'm no professional, but the 45 mg/str appears at the lower RPM's but at the 3000 RPM mark they are within spec of 40.0-42.0 mg/str.
Though a value that I believe is out of spec on block 008 is the IQ MAF Limit @ 3000 RPM. The log shows 32.8 mg/str and spec shows it should be 36.0-39.0 mg/str. Not sure how to interpret this though.
Ack! I missed the other spreadsheet pages! But, I still think that the requested fueling is higher than I have seen for stock: I have data from the son's Golf, which, at the time I gathered data, was a perfect runner, and I see a max of 41.8 mg/str.
"IQ MAF?"
Group 011 around 3k RPM it looks like you're losing boost. Sticking vanes or the N75 isn't responding correctly.
I just uploaded data from the son's car (Group 011) for reference.
UhOh is online now   Reply With Quote
Old December 8th, 2017, 06:04   #33
ihredneck
TDI(s): 2000 Jetta
IQ MAF = Smoke Limitation (last column on block 008 data log)
Was the data log taken while in 3rd gear at WOT on your sons car?? Also, does his car have a tune or any mods?
I agree, the boost drops off around 3000 RPM.
I guess is could be sticky vanes, probably pull the down pipe off to check that, I had manually stroked the vanes, but I will check again.
Another thought is that it is under fueling around that RPM.
Also, I was looking at the time stamps vs RPM from your sons car and mine and I noticed that his went from 1900-3800 in about 4 seconds, mine got to 3800 in about 9 SECONDS....now I know it is a DOG! Again assuming your car data log was in 3rd gear.
1982 VW Rabbit Truck 1.6L NA Diesel
2000 VW Jetta TDI
1992 Dodge W350 5.9 Cummins
1999 Dodge 2500 5.9 Cummins RCSB
ihredneck is offline   Reply With Quote
Old December 8th, 2017, 10:49   #34
indysoto
indysoto's Avatar
Saw some post where someone suggested oven cleaner to free sticky vanes.
2000 a4,G60 single mass, KYB AGX(replaced 2x :|), 215/65/r16's...
2004 BEW Wagon w/ Meyerhoff AutoHaus Runonbeer Sticker
indysoto is offline   Reply With Quote
Old December 8th, 2017, 17:14   #35
UhOh
UhOh's Avatar
Yeah, if I was logging then it would have been 3rd gear. I'm guessing that it was a stock tune at the time: fueling is maxed around 37 mg/str (car now has a Stage 3 tune, with same T4 nozzles, in which case I figure fueling is now substantially higher); log of my car shows max fueling around 49 mg/str - Stage 2 tune with DLC520s.
Sticking vanes most likely. Wife's car had a sticky spot around 3k rpm and I kept working it for a good year before I manged to get it to smoothen out: I should get a log of her car- it's the strongest runner of the lot.
Old Yesterday, 05:56   #36
ihredneck
TDI(s): 2000 Jetta
That would be interesting seeing logs of all the blocks on her car. Also, how could you tell the vanes were sticky around 3k besides pulling the exhaust and watching the movement of the vanes?
I do plan do check them out once I get back from a work trip.
2000 VW Jetta TDI
Old Yesterday, 22:59   #37
UhOh
UhOh's Avatar
Performance-wise everything was great, on the wife's car, except that there was a lull around the 3,000 rpm mark, kind of like it was running out of fuel, flat-lining and then pulling back out of it and resorting to full boost/power. I'd cleaned the intake, EGR and intake ports in the head, so all was clean there.
Here's a graph of what the wife's car was like (I should look around and see if I have one since things have been working well). It didn't feel as dramatic as it looks, though for sure it had a pronounced drop-off. Again, this is NOT what a properly running engine should look like! (I'm pretty sure this is a VNT15 in this car, though I have never looked- ha ha, I'd thought that it had a DMF in it only to find out when I went to replace the clutch that it had an SMF! - why service records are a nice thing to have!)
https://log.malonetuning.com/chart/3...gsKWwo0AAAA%3D
BRM constant low power Caswell239 VW MKV-A5 Golf/Jettas 0 November 18th, 2016 10:06
Prolonged Driving With Bad Turbo Actuatoy and Constant Low Power wizard_of_koz VW MKIV-A4 TDIs (VE and PD) 7 April 28th, 2015 07:59
Constant low power... Concat TDI 101 21 July 28th, 2014 14:32
Constant Low Power Issue - 2003 Jetta TDi ALH 5spd jeremykuz TDI 101 2 August 27th, 2013 10:37
Constant No/Low Power Lapdog TDI 101 9 May 30th, 2013 12:23
Page generated in 0.12496 seconds with 12 queries
[Output: 86.15 Kb. compressed to 74.99 Kb. by saving 11.16 Kb. (12.96%)]
