Best Location for adjusting headlights ??
Sebpt
Bolton, Ontario
2003 Jetta TDI (SOLD). 2005 MB E320 CDI
Do you know a good public place (parking garage, etc.) near Vaughan or Bolton where I could adjust my headlights using the aiming procedure listed here? http://www.danielsternlighting.com/tech/aim/aim.html
According to the procedure, I would need:
- Perfectly flat ground
- A wall where I can put markings on (or tape for instance)
- 25 feet minimum clearance.
My house's driveway is sloped and I think my beams are too low anyways:mad:
SuperJ
Waterloo, ON
2006 Jetta TDI
It's harder than you would think to find a level spot. I've driven around looking for one before. I ended up using my sloped driveway and garage door for the horizontal aiming, and a dark, flat, country road for the vertical aiming. It actually worked pretty well after a few tweaks.
Sebpt
Bolton, Ontario
Vik F said:
humberview, rec center or the rink by the library, I'm local and can lend a hand, lmk.
Thanks! I should be fine, it takes like 5 minutes to adjust
