GrowlerDad
Hi All!
My name is Chuck, GrowlerDad because I am Growler's Dad. I'm new to the Forum and I have an electrical problem on a 2000 Beetle TDI. For those of you who know Growler, the car is the original Growler modified by my son. The electrical issue I have is that none of the accessories work. Engine starts and runs ok headlights and running lights along with the fog lights do not work. No turn signal or wipers, but the windows (electric) and remote key work. Heater fan is dead, and the AC switch doesn't work but emergency flashers DO work. This all started after getting new keys for the car and getting a stage 2 rocket chip tune with an immobilizer disable and egr delete. I removed the lens on the front of the console to put RTV on the immobilizer light and sometime after doing that, everything quit. All the fuses on top of the battery are good. I checked the power strip below the relays and everything has power except the furthest left lug (marked 75x) which used to have accessory power on it I believe and now is completely dead (no voltage with the key on and engine running). could it be as simple as a bad ignition switch or is there a relay that could be bad? I know that this is a long post and I apologize. Please Help! I miss my Beetle. Thanks All!
