While at the body shop, the fuel pump started leaking and eventually could not be primed. This meant that the car could not started to be driven around the shop.
Moved the car back to my driveway, and called "local guru" who diagnosed the problem. And since we have better accessibility, we'll also re-build the alternator, replace coolant hoses under the pump, and replace the fuel hoses.
Also ordered 3A0199171A new OEM Cross Member to replace the rusty one on the car.
So far:
1. Replaced the fuel temperature sensor, and the fuel pump top cover seal.
2. Replaced the fuel pump head O-ring.
3. Replaced the fuel pump head middle seal.
4. Replaced fuel pump four bolts.
So far:
