Blanco98Beetle
I have my TDI Beetle for 4-5 months now.
The car runs like a sewing machine. smooth and no noises...The belt was inspected and looks almost new..
The one thing I have concern with is the Timing Belt Service job was done well over 5 years ago. With the car running fine and only at most 24,000 miles since the work is done , do I still have to have concerns about the age that the job was done over 5 years ago..... I do not want to mess up my engine obviously but also I hate to swap out good parts .
The work was done by German Car Depot in Hollywood, FL
This is from their website ..
Timing Belt Replacement: One of the most important VW Service and Audi services that should be preformed on your VW or Audi vehicle is a timing belt inspection or replacement. If the timing belt is neglected and allowed to break, thousands of dollars of damage could occur to your engine. The recommended intervals for timing belt replacement varies between 40k and 80k miles depending upon the year and model of the vehicle. When your vehicle is brought to German Car Depot for an oil change, a scheduled service or any repairs, our technicians check the condition of your timing belt (this is an easy procedure, often overlooked by other mechanics). When it becomes necessary for a timing belt replacement our technicians follow the vehicle manufacturer’s factory recommendations, this includes also replacing the idler roller, tensioner roller, water pump, thermostat and accessory drive belt.
