midnightoil
- Joined
- Feb 18, 2013
- Location
- Minnesota
- TDI
- researching for a TDI highway driver and occasional tow pig
One big thing i'm wondering to this day though is how much reliable HP I should expect out of a ALH TDI. (about the only thing i'm pretty fixed on is I want an ALH for my swap project) Including how heavy of a vehicle might I put into one if weight is a separate load factor than just torque/hp output, and how heavy of towing, where it might run minutes at a time at higher than stock power levels going through the rockies for instance. Vs power levels I might use for spirited acceleration from a stop.
Like as an example i'm aware there are people that use one Jetta to haul another Jetta which is a good 3500lbs, i've heard of some people it sounds like moving more, and they came in Passats weighing a fair bit which could also tow too. Yet i'm curious what the engine might do even in something like a compact pickup rated at more like 5000-6000lbs towing where the suspension and brakes were up to it, especially if boosted from stock power levels because nobody wants to haul with 90hp in the Rockies...
I'm open to any and all opinions. I guess in my mind i'm looking for "1990's style hauling" back before the crazy pickup power wars started and a 205hp V8 with 300lb/ft was considered enough to haul 7000lbs around or more with the right axle ratio even if you were expected to do it at 55mph. (which might be just fine)
I'm curious what relatively stock internals might give for reliable power - from past reading it sounds like a 205-225hp with 350lb/ft ALH TDI is not unreasonable expectations - yet that's right in line of a light early 90's V8 gas engine. I have a Chevy Caprice with 170hp and 255lb-ft and a pickup with 210hp and 300lb-ft. A car I don't have but have wanted for years is a certain year Fleetwood whose LO5 engine had 185hp and 304lb/ft of torque yet with a low axle ratio could be rated to tow 7000lbs.
Call me crazy but I almost want to slap an ALH in there - while having ample room to work on everything. Yet how would it hold up to having my foot on the floor requiring it to put out 170-210hp up mountain grade with a load, basically meant to replace the V8? Assuming EGT's can stay down, maybe intercooler upgrade, water-meth injection okay, etc. I'm asking it to do twice what it did stock and wonder how long it would last.
To be clear, I don't mind the idea of wearing out the engine faster. I'm the type that only uses my right foot when I have to, and spending the usability faster when you need to is a fair exchange - but I wonder if a half million mile engine becomes a 100,000 mile engine when asking twice the power from it more regularily in a heavier car.
Mostly I want to avoid breaking parts - i'm curious at what sustained power outputs if EGT's are controlled I might expect trouble with mostly stock internals. I don't mind adding something that's an easier upgrade while the engine is out of a car, like I assumed ARP head studs were like that (assumed you just unbolt the factory bolts and replace with the studs?), but I wasn't looking to tear into an engine spending thousands of dollars on internal upgrades either. I'm looking for the low hanging fruit of upgrades possibly including things done during a common rebuild (assuming it'd eventually need one) and not extreme racer stuff. I mean i'd probably be ecstatic beyond belief at 260hp (even if that's a figure only on water/meth) yet i've heard of guys running more so help me understand how to reliably run different levels or what the weak points are.
