Typrus
Whats the difference??? Aren't they both wastegated setups? What else is changed?
The 1Z preceded the AHU. Here is an ancient thread that may help:which one is the predecessor/supercessor?
aka which one is in my '97 canadian passat?
AHU..12MPGHWY said:please be specific which cars have which engine code? What engine would a 98 jetta have
My 98 has a 1Z. I'll get a picture of the build sheet later if you want.IndigoBlueWagon said:Some '97 Jettas have (mine included) have 1Z engines. All B4 Passat TDIs were 1Zs, I'm pretty sure. Later '97 Jettas and all '98s are AHUs.
Where is that located?IndigoBlueWagon said:Sometimes the build sheets are incorrect. I'm not doubting you, but the engine number is the most reliable way to tell.
You are correct. My build sheet is wrong, it is an AHU.IndigoBlueWagon said:On the front of the engine, above the oil filter flange, usually covered with crud.
All '97 1Zs had water-cooled EGRs.Jetter_Sprinta said:Another way to tell is the 1Z does not have the liquid cooled EGR(look for the ribbed aluminum tube on the back side of the intake manifold). Or, in the interim year (`97) are some of those mixed as well?
