mtbr297 said:
Just get a new harness, for about 50 bucks, and be done with it. How much time and energy do we have to spend on this common problem. I have tried all the different remendies, it always came back. New harness, problem solved.
Time & energy is subjective. Most people on this board are enthusiast who like to get involved with their cars. If time was an issue, then most wouldn't be members here and they would simply take the car to a dealer and pay the big $$$ to get it fixed. I don't want to paint everyone on this forum with the same brush, but we seem to be frugal folks. Or at least people who like to tinker. This is a DIY community for the most part.
As for time, it takes more time & effort to cut out & splice in a new harness than it does to pop it of, spray it with some deoxit, give it a squeeze and pop it back on. Especialy with the 4 wire harnesses. They can be upwards of 1 hour if you chase the wires all the way up the loom to the plug.
I hear where your coming from and beleive me, I have convinced customers to replace parts before that could have possibly been fixed, but the time to fix it was more than the time & cost to replace it. That is not the case with the harness. IMO, treating it will cure the problem in 95% of the cases. Im my 4 years of fixing TDI's, I have only ever replaced 3 harneses. One was my own before I found out about Deoxit and the other 2 the customers already had the part with them when they came. All the other occurences of the GP CEL (that were not plug related) were fixed with a shot of deoxit in the harness.
Now that is just my experiences (less than 100 cars). So others may have different experiences and higher rates of failure with the harnesses. But to me, it is common sense to try a 20 minute fix with a $10 can of Deoxit than an hour repair with a $50 harness. If the deoxit doesn't work, it only cost you $10 and a half an hour of your time. And even then, you have the deoxit as a preventative measure to treat the new harness when you install it, so it wasn't a wasted $10.
Now I will admit, there are people whos time is more valuable than money. But those are not the people I wrote this article for. I just don't beleive in throwing parts at a problem till its fixed. I like the methodical approach and trying to diagnose the source of the problem and fixing it starting with the simplest & cheapest solution first. If it doesn't work, well, at least is was cheap and easy, then you go to the next step.
