mrfeb14
any new updates or pictures on this project?
Update 30,000km and five months later still running no stalling.I re-soldered two new wires to the "on" switch and crimped on a new RJ45 connector. Went for a test drive with no issues!
Hi Squishy,
That would be the easiest way to wire a push button ignition in a Mk4 for sure but it requires that you start out with your ignition switch and key lock barrel in working condition.http://forums.vwvortex.com/showthread.php?1188609
thats the one i used when i installed one. worked perfectly and hides nicely where the 12V is.
Exactly, this fix is for when the expensive and hard to replace mechanical part fails.Is the reason for doing this because it's not just the electrical ignition switch that fails? Because if that was all the problem was I can't see the logic in doing all this extra work instead of just buying the cheap part that failed.
She's waiting in the yard for the little ones to get old enough to drive the minivan/her.Are you going to keep the Golf?
