I have a 2004 Volkswagen Jetta TDI with a hard start problem that has been going on for 2 years. It is really difficult to start the first time of each day and then it is fine after that. It is worse when it is cold out, but happens even in the middle of summer. It cranks and cranks and cranks until it finally catches (Around 5 mins) I have taken it to 4 different mechanics and nobody can seem to figure out what the problem is. It is wearing out batteries. I have put a lot of money into trying to solve this problem. We have replaced the fuel filter, battery (twice), the fuel pump in tank as well as pump and supply relays, glow plug relay, and coolant temp sensor. We have also checked the glow plugs and the ECU wiring harness, and cleaned the carbon from the EGR valve and intake manifold flap. Any suggestions? This is a wonderful car, but I need for it to start reliably and not be such a money pit.
