Grinch
Sounds like the experienced people are on this area of the TDI forums. So here is my question.
I have already spoke with Jim at dieselgeek 2x and did not want to bother him again. But my problem is still there. I bled the brakes too low in the reservoir, refilled it and bled out the brakes. I forgot about the clutch and backed out of my drive. She went into reverse but would not go into any other gear. Now I seem to have no transmission. Clutch goes in and she will start, but running or not I cannot engage the tranny and the shifter seems to have no feel to it, no resistance. I bled out the clutch, a lot, but still no luck. i even adjusted the gear selector cables. No change. One odd thing is that the gear selector lever with dampening weight under the hood, the kind of upside down putter, when I move the 5 speed stick inside the car and try to find the gears, the GSLWDW moves to the far right as you look at in from the front of the car. And when it goes there the shifter inside the car will not go side to side. I then have to put the GSLWDW back to the neutral position to be able to move the shifter out of the 3/4 gates and into the other gears, but still no feel to the shifter...
Do I have a problem besides the clutch or do I still need to bleed the clutch again and again?? Then will this shifting problem and tranny problem will go away??
