Old October 16th, 2018, 07:22   #31
Funguy
Fuel Economy: 47 mpg
Deja vu here. I really don't know how the phase one didn't fix this but I suppose there could be more than one event that could cause that code.
Hope they get you rolling asap
Funguy is offline   Reply With Quote
Old October 17th, 2018, 06:15   #32
cmoor052
TDI(s): 2015 Passat
UPDATE
The dealership found that my air box was damaged on the intake side of the MAF sensor and they suspect this is what's causing the high air input signal. They're making repairs as I'm typing this. Hopefully this is the fix.
The damage was on the underside of the airbox so I wouldn't have noticed it without disassembly. Thankfully, the CARVANA warranty covered the repair no questions asked. Just frustrated that I have to be without my car while the fix is being done.
cmoor052 is offline   Reply With Quote
Old October 17th, 2018, 06:30   #33
Funguy
How does the underside of the airbox get damaged? That is weird. That makes sense to me though as a cause of the POBD code.. Not that I know jack.....
Old Yesterday, 04:37   #34
740GLE
Also the underside is the dirty side, unless it messed up the seating surface of the filter, no idea what the techs are thinking. Smells really fishy, especially when carvana is picking up the tab.
Best of luck not having to make a return trip after they make "repairs".
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent Fuels & Lubricants 4 February 21st, 2011 04:21
Think I need a new injector pump. Getting an actuator code & fuel temp sensor code codylent VW MKIV-A4 TDIs (VE and PD) 5 February 18th, 2011 14:39
P0226 Throttle Pedal code went away and was replaced with a glow plug code. Fixed. thordehr VW MKIV-A4 TDIs (VE and PD) 0 June 6th, 2010 21:11
Airbag fault code together with low voltage code msa6 TDI 101 5 April 24th, 2008 13:38
Vag com code 00527 - code reader P1161 tdidieselbobny TDI 101 4 December 11th, 2006 13:07
Page generated in 0.13743 seconds with 12 queries
[Output: 64.09 Kb. compressed to 57.63 Kb. by saving 6.46 Kb. (10.08%)]
