View Poll Results: Which AMSOIL?
Premium API CJ-4 Diesel Oil (DEO) 100 28.25%
European Car Formula Motor Oil (AFL) 254 71.75%
Voters: 354. You may not vote on this poll
Old May 18th, 2011, 10:00   #1501
Crows Synthetics
Crows Synthetics's Avatar
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Post Announcing a Full Synthetic At current Petroleum prices.
Hello to All.
Here is hot off the presses announcing a Synthetic which can fit all user needs, (Diesel and Gas), and At current Petroleum CJ-4 specs, and Backward compatible as a Fuel efficient and standard Drain lube product.
AMSOIL OE 15W-40 Synthetic Diesel Oil provides excellent protection and performance in both on- and off-road diesel engines for the original equipment manufacturer’s recommended drain interval. It meets API CJ-4 specifications and is suitable for both modern and older diesel applications. AMSOIL OE 15W-40 Synthetic Diesel Oil exceeds the higher performance demands of modern engines and withstands the stress of heat, soot and acids to help prevent deposits, wear and corrosion.
At $4.67 Qt. /$ 18.67 Gal. Delivered in 55 Gal lots, this is approaching Cl/CL spec lubes, and has met specs for all engine drain intervals. Designed to allow users to maintain current servicing schedules for all component intervals, it offers the confidence of a true synthetic from the company that introduced the First A. P.I. Synthetics to consumers in 1972.\
NOTE: There are several new oils as well.
Break-In Oil (SAE 30)Designed for High-Performance and Racing Engines
Z-ROD 10W-30 and 20W-50 specially engineered for classic and high-performance vehicles.
Allow me to assist your operations in reducing Maintenance costs and extending the life of your Components and the range of the fuel you pay for with cash.
OE 15W-40 Synthetic Diesel Oil (OED)
Formulated for Excellent Diesel Engine Protection and Performance
See Pricing Information or Place an Order
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
2.5-Gallon Bottle
2.5-Gallon Bottles (case of 2)
30-Gallon Drum
55-Gallon Drum
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL, The First in Synthetics®, to do the best job protecting your engine.
Bill Crow
Don’t be a victim of big oil Propaganda
Bill Crow - Amsoil Direct Distributor
ZO # 1176229
1251 Reiker Ford Rd.
St Clair MO 63077
1-636-629-8033
E-mail - Bill@FreeOilHelp.com
www.FreeOilHelp.com
www.BillsOilHelp.com
2009 Jetta Sedan TDI --- 2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD---New Holland T1520 Diesel
www.FreeOilHelp.com --- www.BillsOilHelp.com
Crows Synthetics is offline   Reply With Quote
Old May 18th, 2011, 11:09   #1502
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Nothing like spamming us with a complete copy and paste.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old May 19th, 2011, 04:28   #1503
LGV2001
Milehigh, I have been using AME in my Duramax with good results. I tow a gooseneck trailer with a GVW of 23K in 100 degree weather and several reports of very low wear metals...8-11 PPM iron @ 12K miles. AME 14.2 @ 100 is thinner than DEO 14.6 @ 100 but the HSTS is higher at 4.3 to 4.0.
In your TDI you might look at AMO which has lots of zinc with 14.6 @100 and HTST of 4.3. I just changed my ALH to this hoping to get 300K out of the cam.
LGV2001 is offline   Reply With Quote
Old May 19th, 2011, 12:51   #1504
milehighassassin
Fuel Economy: 43
I am about 1500 miles away from a uoa on the DEO that I have been running.
I think the deo is a quality oil. My oil temp concern is egt related. Thicker oil would be a bandaide solution I think.
We've had good luck with the 15w40 marine in the duramax. Recently switched it to DEO because it doesn't tow a lot anymore. It sees limited heavy towing and a lot of highway.
Old May 25th, 2011, 09:50   #1505
XFIRE
TDI(s): 2011 Golf
Fuel Economy: 37
Default New Golf TDI - lubricant information
As a brand new happy TDI owner, I was hoping to find this forum filled with factual information on maintenance and care related to synthetic engine lubricants; Amsoil included. Instead it seems like I stumbled upon a hornet's nest of "rant & raves" of argumentative folks. I was under the impression that the forum was a means of exchanging intelligent, helpful information and experiences. Hopefully I can be guided to the correct area.
XFIRE is offline   Reply With Quote
Old May 25th, 2011, 10:27   #1506
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Thumbs up
I agree with you I am posting info and it seems as though it is not what they want.
I do use the paste feature as i am missing some fingers and it is much easier for me.
Amsoil on Line Store
ZO # 1176229
St Clair MO 63077
1-636-629-8033
www.FreeOilHelp.com
Old May 25th, 2011, 11:15   #1507
Abacus
That helpful B4 guy
Abacus's Avatar
No, you are posting sales pitch info and not real world UOA data. Every oil says how great it is on the package, would you expect them to say what harm the oil does to your engine instead?
Even Prothe looks good to the layperson...
Be honest and back up your claims, then people will respond to you better.
I would like to see the UOA on the '96 Passat with the 50K OCI's, but then again, 278K isn't all that much for a TDI these days.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old May 25th, 2011, 12:56   #1508
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Post
I don't have control of IOA if the customer don't provide one as you I would love to see the IOA myself.
The fact he has 278K doing 50K OCI's should be at least an eye opener. At some point I stoped questing the product as I have seen so many testimonials I over came my fears.
Try this link 570k miles when the odometer quit. On the same link the Explorer at 570k the guy has a delivery buss. I have racing testimonials as well.
At some point I decided to get on the train and enjoy the benefits of Amsoil product.
I have several IOA of my truck on at 29k on a PSD.
Bill
Old May 27th, 2011, 00:40   #1509
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
Do *you* recommend OED for VW TDIs?
DPM is offline   Reply With Quote
Old May 27th, 2011, 05:09   #1510
cheezy
cheezy's Avatar
Fuel Economy: NB-52.6, B4-37 city on 2 yo fuel!?
You are in the correct area for Amsoil informations per your car.
So, I'll explain the hornet's nest phenomenon a little bit: in most internet forums there are now anti-Amsoil people whose intent it is to take reasonable conversations into personal rants, in order to shut down the threads. Their motives are varied from random anger of a bad day to carrying a personal vendetta against certain Amsoil sales people. Don't let these few people deter your curiosity.
I have been an Amsoil Direct sales person for over 10 years now, and here is the extent of my soapbox, as I do not sell the stuff for profit; get the correct application for your use and it works. I've used their products in motorcycles I raced professionally, chainsaws and 2-stroke dirt bikes, gas vehicles, and diesel vehicles. Take a look at the posts by "Tooslick" and "Bob Fouts" and you'll likely find excellent info. for your vehicle.
Their gear lubes are great as well; the older TDIs use GL-4 spec'd lubes, and I'm not sure what the newer ones run (GL-5s maybe?), as we haven't bought newer TDIs yet. Finding the products can sometimes be a hassle and that is why I became a "Dealer" many years ago; it comes to my doorstep. Have fun with it!
cheezy is offline   Reply With Quote
Old May 27th, 2011, 09:56   #1511
TooSlick
TDI(s): Audi 100S
Mile High.
A 5w-40, HD diesel oil (CJ-4/SM rated), is plenty thick for a TDI, even with lots of towing. For example, the DEO formulation is ~ 10% thicker than a typical VW 502.00/505.01 Spec oil. As someone mentioned, you could also run the Amsoil 10w-40/AMO, which is about 8% thicker than the DEO, 5w-40. I like to test things, so I'd probably try several different Amsoil formulations (5w-40/10w-40/15w-40),and have them analyzed after 10k. But I expect the results would be so similar that it might be a wasted effort.
TS
TooSlick is offline   Reply With Quote
Old May 27th, 2011, 12:38   #1512
milehighassassin
Fuel Economy: 43
Thanks Ted,
I have been pretty happy with DEO, I was just concerned with the long pulls under full load and high EGT's might be doing a number on the oil. UOA very shortly. Although the oil that is in there now has not experienced a lot of towing. Some light winter towing but that is all. In the winter the temps never get as high as they do in the summer.
I am coming up on 10k on this oil. I was planning a UOA and a oil filter change for good measure. At around $6 for a filter it seems silly not to.
Old May 30th, 2011, 06:46   #1513
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
Post
I am sorry if no one has responded to your Question.
I would not recomend any of the OE oil with out IOA's in the TDI's.
The truth they just might work but you have two oil for the TDI's why go with a oil that is not stated it is for the spec oil.
Bill
Old May 30th, 2011, 07:51   #1514
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Bill
For places with mild winters, this outta work for pre-CR TDIs. OED is a CJ-4 synthetic oil. For those TDIs that allow API CH-4 and better (VEs), there's no issue using this oil. PDs have run well with CI-4+/CJ-4 oils (Amsoil DEO, M1 TDT, D1, D1 ESP, T6), so this should work in PDs also.
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old May 30th, 2011, 08:32   #1515
Crows Synthetics
TDI(s): 2009 Jeta
Fuel Economy: 38-42
FYI he might of seen we have a OED for diesels it is a CJ4 oil.
Bill
Page generated in 0.21230 seconds with 11 queries
[Output: 148.27 Kb. compressed to 126.24 Kb. by saving 22.04 Kb. (14.86%)]
