Ok, Here is a little background
Last week I had a pulsing in the engine. After talking to the local (90miles away) VW dealer and reading a couple post I changed the Flywheel and clutch in my 02 jetta. After the install the engine started much quicker but was a little louder at idle while in neutral. When I pushed the clutch in sounded normal. No slipping, nothing loose. However, it still had a pulse. This week I started changing the timing belt.
Here is were I am at. The belt change went Ok, aside from not being able to see the timing marks on the Sach flywheel. When I started the engine the first couple times, everything was fine.
So, I went to eat, grabbed the cable and computer and went back to set it with Vag-com.
Now when I start it OMG, it sounds like the piston is ready to bust through the head. It still rev's ups and pretty quick at about 2000 it sounds about normal.
What is going on???
What is going on???
