Torque Converter #?
Kayakkermit
Ontario
Jetta TDI, 2002, Silver
Two questions for the gurus:
#1, on a 2002 Jetta, is the TC different between a gas model and a diesel model, and 2) can anyone give me the part number for it?
I'm having "issues" and I want to make sure the shop put the right thing in.
If they did, it sounds like there me be a higher-temperature pressure leak somewhere else in the system other then the valves they replaced for TC lockup.
Help would be, as always, appreciated.
MOGolf
underneath something
2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
TC is 099 323 571 F (new) or FX (rebuilt). Code letters are QCDD. Used on 1.9L TDI and 1.8T gas automatics.
