stanadyne fm-100 5 micron install w/mann pre-filter - installed :)
burpod
teh stallionz!!1
cape cod, ma
82 rabbit vnt ahu, 98 jetta vnt ahu, 05 parts car, 88 scirocco.. :/
i may write up a thread on my epic tale of PD turbo install hell but it was all i could do to get it off/on and take some pics. also, the thread might just be better summed up as holy crap that pd egr cooler is a major ****** to remove! ;)
milehighassassin
Fort Collins, CO
2005 Golf TDi PD, Reflex Silver
Fair enough. Did you access the allen bolts (to the intake mani) from the top of the motor or did you crawl underneath?
Little of both?
burpod
teh stallionz!!1
cape cod, ma
once the egr cooler is out, and it *must* come out as well as the turbo inlet pipe, the rest is fairly easy - all bolts for the intake manifold can be accessed from the top. there are 6 6mm allen bolts to take off the stock intake manifold from the head - you want to take it out in one piece, as opposed to the top part and then the part with the flaps. i had the car jacked up the entire time, since you *will* need to get under the car to get at everything for the egr cooler and exhaust manifold.
milehighassassin
Fort Collins, CO
Thanks a lot. I didn't remove the EGR cooler, which was probably my problem. I have no reason for the EGR cooler since I blocked of the EGR.
When I have time I will give it another go.
BTW... the TIP is a ***** to get on again. :mad:
burpod
teh stallionz!!1
cape cod, ma
update...
just relocated this in my golf as well, here's a couple pics. it's much nicer in this location. wish i had realized in the first place it fits here:
the whole picture (kinda crappy focus):
http://picasaweb.google.com/burpod/GolfEGR#5266379065981169810
closer up:
http://picasaweb.google.com/burpod/GolfEGR#5266379076407871794
i love this setup. to install this all you need is the filter head ($35), a filter ($15), a few small clamps (<$5), some fuel line ($10?), and modifying the OEM bracket (easy) and you have either 2 or 5 micron filtration :)
oEo
Lancaster | PA
'04 Golf TDi PD ::Indigo Blue::
burpod said:
update...
closer up:
Excellent! That looks really good.
robnitro
NYC area, NY
2001 Jetta TDI GLS silver
Did you use the 5 micron 6" filter? It had enough room to fit? Also, which heater did you buy?
UFO
A mile high
2001 Beetle
burpod
teh stallionz!!1
cape cod, ma
yes i use the 5micron (actually filters out 92% of 2micron particles) 6" tall filter. fits fine if you just modify the oem fuel filter bracket as shown in my pics. i bought the side-load heater that was on the reliableindustries site. not sure what their site is up to now, it's changed since when i originally bought mine, but i'm sure google will yield other places to purchase it...
milehighassassin
Fort Collins, CO
UFO said:
There is no information on that site. "Under Construction". Is there any technical information on the Stanadyne fuel filters like you can find on Racors, like mounting hole dimensions, overall dimensions, flow specs. I've done some searches and found nada, so far.
Depth = 101mm
Depth = 105mm
Height =162mm (smallest) 243mm (largest)
http://www.stanadyne.com/docs/pubf/99889 FM Brochure.pdf
There used to be a PDF of the exact dimensions on their site, I cannot find it. Other than that, their site is working fine for me.
Lots of info all of which has been covered:
http://www.stanadyne.com/docs/pubf/99795.pdf
http://www.stanadyne.com/docs/pubf/FM Efficiency tables MB2051.pdf
UFO
A mile high
2001 Beetle
That's excellent, thanks very much. I don't know why none of this turned up on my google searches, but it's exactly what I needed.
Rod Bearing
Fort Worth
Several
These old threads are more important now than ever before. Fuel heaters are a definite help on northern vehicles and may well aid the HPFP in living a long and happy life after warranty.
milehighassassin
Fort Collins, CO
T_D_I_POWER said:
In ON, would be the any VW dealer. Ask for the Performance Formula
Here's the dealer locator
http://www.stanadyne.com/view.php?id=43
I assume since this thread is about the Stanadyne fuel filter setup, then that means he is asking about the filter, not the fuel treatment. VW carries the treatment but not any filter components, at least not my VW dealer.
coronan
Reno, NV
01 Golf
What kindof filter life are people getting out of the 5 micron????
I Feel like mine might be plugging after 5k mi. Either that or its the hot weather giving me more smoke at full throttle.
Farfromovin
Torque Addict
Ventura, CA
03 Golf 2dr- PD150 6m
I'm not sure about these particular filters but the CAT 2u filters are getting solid 40k-60k service intervals on our cars. What I am sure about is hot weather increases smoke ;)
milehighassassin
Fort Collins, CO
I get 30k or so. I usually change it once a year.
I don't think it needs changed at 30k but that is about how many miles I drive in a year.
