bogievw
- Joined
- Jun 25, 2007
- Location
- Madison, WI
- TDI
- '02 Jetta Wagon- why yes, it is silver. How'd you know?
2000 Golf. It's been sitting a while and now won't start. I ran biodiesel in it years ago. I've been through the "car won't start" thread (option 5: cranks fine but won't start). Fuel system up to the injection pump checks out fine. Moved on to the "bleed/prime fuel system".
Tried to pull fuel through the fuel return line, not only did I not get any fuel after lots of pumping the system was not holding suction.
I'm figuring that I'll need to change the IP seals. Is there anything I'm missing?
Thanks in advance for your help and consideration.
