Auto Dimming Mirrors
chaos2984
maryland
06 Jetta
So I found a way to add the auto dimming feature into the mk5's without the rain sensing option. I had a B5 S4 that recently got totaled. I kept the rear view mirror to try to sell. I was in the jetta replacing the headliner and found that the rear view mirror has the same mounting style as my B5 did. So i tried it and went right on. So i got the harness connector from a B5 headliner for the mirror. I just wired up the mirror today and it worked correctly.
You can use the mirror out of a B5 S4 or a C6 A6 that has the compass as well.
I am trying to find a solution to the exterior mirrors to retro fit. I also have a b6 passat wagon. that the mirrors look identical to the jetta. I am going to try to see if they will fit. I will run wires to each mirror to add the auto dimming to the exterior mirror as well. Its a much needed option.
