Replacing the Thermostatic Tee or Fuel Filter Check Valve
DeliveryValve
Western US
Passat GLS Wagon
The correct Thermostatic Tee part number for the 2004 and 2005 Passat BHW is 1J0 127 247 J
But the cheapest I found the Tee is $45 and it's a genuine VAG part.
Meanwhile all the ALH and other PD motors use 1J0 127 247 A, which I can get an aftermarket part for under $10.
So what's the difference? Can I use the 1J0 127 247 A on a BHW? Or I need the more expensive 1J0 127 247 J for the car to run right?
DeliveryValve
Western US
Passat GLS Wagon
I wonder why almost all the part houses use the "J" for the BHW. But for the ALH and BEW the "A" is listed?
