franklinstower
I hate that my cruise changes speed in 5 mph increments when using the + and - . Is there a way to change the increase and decrease faults in vcds?
Proof again that folks don't read the manual...Doesn't the RES and SET buttons (once you're cruise control is controlling your cruising speed) change the set speed by 1mph for you?...
Yes, same deal with my 2016 GTI. 2016 was the year they made the switch.odd, our Alltrack has the cruise on the steering wheel that adjust 1mph via the +/- button from the factory.
15's didn't come with adaptive cruise control but I wonder if it's possible to change with VCDS? Mine has the collision warning so it seems like the car would have what needs to have adaptive cruise.Adaptive cruise control? Or normal?
The SET/RES would change +1/-1 increments.So, on the 2016-->, then, is there a way to increment the speed by 5mph (or 10km/h for us Canadians)?
I probably make more use of the +1/-1 than the larger increment, but having both is nice.
I actually bought a replacement steering wheel for the paddle shifters (Canadian models didn't come with paddle shifters) and was quite pleased to see that the wheel also had buttons for adaptive CC.15's didn't come with adaptive cruise control but I wonder if it's possible to change with VCDS? Mine has the collision warning so it seems like the car would have what needs to have adaptive cruise.
