flee
I would suspect the fuel pipe itself. Is it obstucted or dented?
The above is also good advice if you've run the tank dry, and now have fresh fuel in the tank (maybe from roadside assistance!)Follow the four steel injector pipes from the Injector Pump over to each injector .... there, on top of each injector is a 17mm "line-nut" that holds them on the injector.
All you need to do is loosen each injector nut about a half turn (plus or minus a bit, and they are tight). Lay some paper towels over the injectors. Then crank the engine over about 15 to 30 seconds. Tighten the nuts ... attempt to start the engine. If no start... repeat!
Considering the engine ran for about 60 seconds, it's likely air is only in the Injection Pump and hard lines over to the injectors. But, after several attempts, as described above, if the engine doesn't start, you'll most likely have to purge the filter and IP of air... then attempt as described above.
After changing the fuel filter, I always start the engine and take the RPMs up to about 1800 for at least 1 minute .... that will purge all air. Been doing that since my first VW diesel back in 1980...never failed one time!
