I've already been a victim of a HPFP early on (11k miles) and am now
turning my attention to the long term future. I currently have Geico MBI till
100k but wanted to get some thoughts on purchasing the 2 micron kits now
versus just waiting till I hit 100k miles and then installing. I currently have
40k miles on the car. Anyone buy the kits even though they have an
extended warranty?
2 Micron (Andrew) is a great guy, does great work and his fuel filter/bypass
and his timing belt guard are clever, great. I don't know of any "saves" with
his system. It will not eliminate all cost but should save the two Aux pumps
and injectors, as well as need to flush all lines and tank out. The belt guard
should keep the timing belt safe from crap getting in there including a
shredding serpentine belt.
The issue is with any modification and warranty/maintenance service plans,
not just these modifications. The belt guard is pretty benign but it is a Mod.
The fuel system mod is more involved and could be reason to deny a repair
claim, with anything to do with engine. Transmission? Who knows.
I had VW warranty (actually CPO warranty through another company) about
to expire. In anticipation I bought another plan with another company. So I
was double covered. However because I had the 2 Micron on it they both denied
paying for repairs.
YOUR HPFP is now covered by VW until 10years, 120,000 miles.
So the answer is
don't modify your fuel system until after 120,000.
You already have your powertrain warranty by until 60k miles. Which
covers your turbo (another big expensive failure point. Also the turbo
can take out the DPF (emission) is covered until 80K (by Fed law).
Keep in mind Geico will let VW pay for these if they can, Geico is
secondary. Clever having customers pay for something you are already
covered for. Your service plan really only kicks in after 80K or 120K...
which is of course after your secondary coverage ends. They know
this.
The extended "warranty"/service plan folks will make sure the manufacture
pays first before they come into the picture. They sold you some thing you
already have with VW.
Service plans are expensive, $2000 to $6000. I would take that money and
invest it for rainy day (repair). Since you have the policy, read it again and
make sure you cover yourself for not being denied due to one of the many
exclusions.
Read the terms of your warranty carefully. They never pay for wear
items, tires, brakes, hoses and belts. More important if there is damage
or repair required because a brake, tire, belt, hose failed that is NOT
covered. Example, say tire blows up and it goes into the drivetrain or
suspension. OK you have to pay for tire. However all damage caused
by the tire is NOT covered. It is because they do NOT cover tires...
Hose breaks and causes car to overheat. Damage is not covered because
hose is not covered. READ YOUR POLICY, in vague terms this is the
implied coverage or lack thereof.
ANY modification you do may void plan or violate exclusions. Even if the
repair you are claiming for is not related to Mod, they may balk at paying.
If it is an expensive issue: HPFP, Turbo, Serpentine Belt taking out Timing
belt, they will send an adjuster. They will see the fuel modification and if they
can connect it, they will not pay. They will claim the HPFP and Turbo were
effected by Mod. They will say fuel contamination caused belt to fail. They
don't cover belts remember..... Trust me, the bigger the repair, the more
they will try and deny your claim.
Bottom line I would NOT Mod your car. I would do regular maintenance and
inspections and DOCUMENT IT WELL. Another disclaimer is they will try to
prove you did not get proper maintenance or bad maintenance to deny claim.
This may be an issue for DIY'ers who change their own oil.
Recommend you keep an eye on the serpentine belt, replace it every 40K.
They tend to fail about 60K although I recall recommended replacement is
120K. If it fails it can (does) go under timing belt cover, causing the cam
timing belt to be fouled and might cause valves and pistons to collide. Belts
are NEVER covered, so your belts are on you and any damage they cause.
If they fail and cause major damage you are not covered, like my tire blowing
example above.
The other big items that fail and cost big money, Turbo fails and takes
out DPF and EGR valve with oil.
However it ismy opinion VW covers
your Turbo until 60K miles. The DPF is covered until 80K miles.
I could be wrong on this VW coverage. Your mileage may vary
(pun intended).
Last the 2 Micron protects not the HPFP but the rest of the fuel
system from a HPFP failure. Since the HPFP has 10yr/120K mile
warranty (true warranty) by VW, including collateral damage, I
would not do the Mod at this time. VW has NO MOD exclusion.
Live life and don't modify your car (until out of warranty). When
you hit 120,000 miles I would not hesitate putting on the 2 Micron
system.
Of course you could always put it on and make sure you take
it OFF before you have your car towed into VW?
Read policy.
Modifications are almost always forbidden. Now if you
put on fancy aftermarket rims and your transmission failed would they tell
you NO to suspension or transmission repair/replacement? May be. I guarantee
they will send someone out to look at your car and "adjust" the claim. If the
EXPERT says the non-OEM rims caused it, you are done. This is a made up
example, but a thread on this forum had a VW warranty claim on clutch
denied due to a reprogramed ECU and shifter Mod....
