GeWilli
Yeah so i'm working through GoFaster's thing. But since I can't do anything for a few days while it is being driving around (and i don't have parts at the moment) lets do some good old school GeWilli hashing a problem out online. Yeah? Sound like good old days fun? I thought so to (no not really, i worked so much this weekend alone and with no resolution on the problem on the car that i got sick).
Brief History: Downpipe fell off going to a race before Thanksgiving. Tank was nearly empty - planned to fill it up but, well downpipe fell off. It wasn't being driven (much). So I go to pull the flange off (well a friend with smaller hands did the deed) and the top two studs snapped off. Great. Now i had turbo with broken studs. So it was just driven a bit but mostly parked. Parked at the airport while i was at Nationals. It was cold but the B50 was working okay in the tank.
Get to New Years day. I'd procured a replacement Downpipe, and some glow plugs for the Golf that didn't want to start in the cold. Replaced the battery in the Golf when the plugs helped it start evenly but still too cold to really start well (time and trip meter would reset). With that car working I went to take the Passat apart. Turbo off. Got the studs out. It was sitting on ramps in front of the house (not on grass, on driveway) outside waiting for it to warm up before putting it back together.
Well. Golf catches fire. It is 19°F and I have to put the passat together because we have to be somewhere later in the day.
Everything went back together great except there was no power. No boost. Gutless off the torque peak. Drivable but not right.
So with my girls out of town this weekend I went to work on it. Started with Thursday night's trip to get some vacuum hose length.
The MAP hose was short. I added a section and made sure there were no kinks.
Didn't help.
Took fuel filter out thursday night after the hose didn't help (it had B50 in there as I had mentioned) warmed it up. And on saturday I flushed it with regular diesel a few times. Filled the tank up with regular diesel (it was warm 55F).
Didn't help.
BUT there are a good number of bubbles coming through the hose at idle.
Yes it did have the 00575 code. Saturday driving around (since clearing the 00575 code) i don't have a code.
Hooked a T into the Red hose. Boost, but nothing above 8 sustained spikes to 10 but settles to 8 no matter what.
watching block 011 at this time i noticed that below 2000 rpm i was seeing higher than requested boost, by 200 or so. And I'm getting boost w/o load on the car (parked rev'n the throttle)
Hooked a T into the blue hose. So it was seeing pressure. When i slowly brought it up to about 2500 rpm in 3rd gear and put the throttle to the floor the pressure would go to zero. and i'd be down well below requested on block 011.
Hooked the T into the MAP hose and boost was consistent with Vag-com.
After Saturday's saga it appeared the N75, wastegate and ECU were seeing and doing what they were supposed to. Just no boost or fuel (requested fuel was low to match boost).
What to check next? Well Sunday I started with the AirBox. It was good.
Next step. Take the downpipe off to see if the 'new' used cat was plugged.
That helped actually, but still no boost (better turbo response). So with a hammer drill and my brother's help we gutted the cat, i mean performed an exhaust adjustment.
And just because Lug_Nut suggested it i pulled the intake hoses off (air box was in great shape) and checked. No rags stuck against the intercooler or in any other pipe.
And that's how it stands right now...
Thinks i haven't done:
Pull the fuel pick up out (tank has 18 gallons indicated - took the fuel out of the golf and put it in there).
Remove the Check valve (good idea?)
Pull intake manifold back off.
I used one of TDIPart's gaskets on the intake when doing the head and just re-used it when it was20 degrees and i had to get the car working. But it was slightly bent despite my care. No i don't remember a crease but i also didn't really check for one. So it is bugging me.
The EGR pipe seems tight but something could be keeping one of those gaskets from making a perfect seal above 8psi.
I get 10 psi spikes that tail off to 8-9psi. Even when the car is requesting 1800 (get max 1500 on actual in the ECU).
N75 appears to be working (from readings off the blue and red hoses directly with a gauge) and the ECU is seeing proper MAP readings that coorelate with a gauge 't'd into the boost line.
There are a lot of bubbles (steady stream of little ones) coming out of the fuel filter at idle.
The car is not smoking.
Just gutless, drivable around the torque peak as long as you don't have to go up hill fast or accelerate much.
Until the fuel gets used up (or i siphon 6 or more gallons out of the tank) and until we hit the weekend so I can work on the car sometime other than in the dark. Does anyone have any suggestions?
It is our only car as i mentioned (with the Golf being a stinking car-b-que in the driveway).
Fuel would be the simplest solution that B50 should have been pretty gelled up at 20°F and i don't think the 55°F we hit on Saturday is warm enough to re-suspend it. I've re-used gaskets before, but then again it could be bent and have a small leak only at pressure above 8psi.
Thoughts?
Comments?
Peanut Gallery?
Didn't help.
Didn't help.
Thoughts?
Comments?
Peanut Gallery?
