fouillard13
ok, twice now this has screwed me around in the cold and my car wont even attempt to start because of this stupid switch. not happy. im glad it happened at home and not at work because I swear I woulda burned the car to the ground if it left me stranded at work and not able to get home at -35 with a head and chest cold.
I was told I can stick a paperclip as a jumper into the 2 prongs if I take the clutch switch off/out so I no longer technically need to press the clutch down to start the car. I will still press it out of habit and because its in gear, but I dont want that POS clutch switch leaving me stranded anymore.
so I basically take the panel off from by the pedals, find the switch which should be easy, unplug it and stick a jumper wire in there or what? is there anything else I should know/do or is it a pretty simple thing? looking at doing this tomorrow when it warms up to -19. hoodie weather.
