Bill1975
Im a new TDI owner, so I'm still learning the ropes. I have a 2011 A3 with 89000 miles, I just purchased it two days ago.
So far the car is great, however this morning I started the car after it sat over night. The motor cranked for 2-3 seconds before starting. Not terribly long, but longer than I'm used to. I then saw the "Diagnose Dan" video where he replaced a faulty VVT unit that was causing a long crank time on a cold start. I'm not sure if this is the same issue, or just a glitch. I occasionally got random, long ish cranks on my gas cars even with a good battery. It's hard for me to know how long a long crank is.
Also, according the the manual, I need to turn the key without starting the car and letting the glow plug light go out before starting. I generally forget to do this as I'm not used to it. Not sure how critical it is since temperature is here are in the 60s or 70s.
