Scott_DeWitt
Are those gears lapped, ground or left in hobbed finish?Conversion kit
http://www.eurotuning.cz/images/file/gearbox_conversion_kit_us.pdf
VW tuning mag article
http://www.vwtuningmag.com/gearbox-conversion-kit/
Unfortunately, no. Here was his response.
"Hello Curtis,
We still don't know why cruise control doesn't work at added gear at some cars. However, we are trying to find it out. We'll inform you when we know more.
Regards,
Radim"
And August??Isn't most of Europe on holiday in July?
Tony
Good news. Did you get an indication of what the problem was?It took three tries, but Mark Malone did it. 2004 BEW (1.5 stage w/ EGR delete), Eurotuning 6 speed manual, with a fully functional cruise control. Thanks Malone Tuning.
Finally did my first full tank of fuel since the 6 speed conversion.Now, what would the payback be say comapared to a 5th gear swap to a .658 or .622 5th gear swap on its own?
900 plus miles all around San Diego county, just normal daily driving with no attempts to buck up the mpg.
39.4 mpg - just near the top of my normal range (36-42). Not unexpected because I had been running a .622 fifth gear for more than a year. Also do not have my Scangauge II hooked up.
All told, I have 1500 miles since the conversion and I still love the smooth, even shift points. My very long 6th gear is not an issue. Running 3.157 final drive and oversize 185/70 x 14 tires. Not a single issue for me since the conversion.
If you are thinking about going to a longer 5th gear, I seriously suggest you spend the considerable extra money for the six speed conversion. It is just that nice!!!
No, John, we don't offer .52 ratio yet. You are driving with ratio .59 for a few months now, do you really think heavier ratio would be better for you?Radim,
Is the .52 gear set availible for the T-5 now?
With the 3.157 final drive in the CTN transmission - No.No, John, we don't offer .52 ratio yet. You are driving with ratio .59 for a few months now, do you really think heavier ratio would be better for you?
Radim
Hello Adam,
Installed the kit this weekend
Build quality on the kit is very good
Took the transmission out and replaced the clutch and 2nd gear syncro at the same time
Transmission was stupid heavy and very awkward to get back in on my own
Got it all back together and went for a drive - 6th gear revs real low on the highway
Pops out of gear in 5th; the only way to keep it in 5th is to hold the shift lever forward. Adjusted the shift cable all the way forward as well - no improvement - going to have to take it apart again and adjust the shims on the shift rail-rod.
Odd... I was very careful to make sure that the shift fork was centered on the syncro dog in both directions. Well, at least I don't have to take the transmission out again in order to add shim(s) to the shift rail/rod.
Radim, if you have any helpful hints from any of your customers that have experienced the same, I'd be most appreciative.
