Ronstarman
Boy did I open a can of worms. Found a autostore that let me change my front brakes in their lot. Had to borrow impact driver,and several other implements of devastation. Loosened lugs on passenger side and went to loosen drivers side and broke 2 sockets and impact wrench. The last place that changed my front tires must of had a gorilla tighten the lugs. Had to get a cheater pipe and a good breaker bar and socket and literally stand and jump on bar to get loose. Figures passenger side was the easy one. Brakes looked good,but changed anyway with new rotors and pads.
Came time to do drivers side and that is when and where the problem began.The caliper cup was hyper extended made it hard to get back seated in the caliper .Both inner and outer pads were down to the metal. Put new on and come next week am changing both brake hoses and the drivers caliper,since passenger one moved smooth into recess. Should I replace both calipers as well when I do replace? Or just the one?
All info does help me be a happy camper
Ron
2/99 VW Jetta TDI 1.9 5 speed manual trans
Ron
