Since buying the wagon, I have driven about 3,500 miles and it sits approximately at 91,000 miles. Here recently, it has been having some issues while starting, as in I turn the key, and it won't start. Turn the key again and it won't start, and finally on the third try, it starts. However, I tried to get it to start this morning and it just wouldn't turn over, plain and simple. I could tell it was trying as I heard the starter going and the lights on the dash came on, but it just wouldn't ignite.
Over the past few weeks too, there has been some smoke come from the exhaust, and even though it is brief and only on start-up, it still has me concerned as to why that happens. Not black smoke, but kind of a gray-blue color. Once the car has started, the smoke goes away and it runs fine. The check engine light came on and the code was PO128 which according to the OBDII computer means a coolant thermostat issue.
I am afraid to try too many times as I don't want to burn out the starter, and I don't know if the timing belt is toast. Is there any way to tell if the timing belt is broken/needing replacement? From reading the forum and looking at the recommended mechanics in the area, there are no "VW Gurus" around me this side of the Canadian border. I live approximately 25 minutes south of the border, and therefore, Seattle is about 85 miles away too.
The only thing that gives me a little hope is that the battery light on my dash comes on and stays on when trying to start, which may make me think it is in fact a low battery and a light or something was left on by accident.
Any ideas as to what the issue might be? Where might I get a good timing belt kit, and does anyone know/trust anyone in my area (Bellingham, WA and the surrounding Whatcom County) who would be able to repair my wagon, at a reasonable cost and if I provide the belt kit?
Thank you for your time, I appreciate the help and advice. This is my daily driver as my other vehicle gets half the mileage my wagon gets.
If there is an issue with the timing belt, will it act like that? I hope it is only a battery issue... I will be buying the timing belt kit and getting it taken care of soon. It is hard to get time to get it into a shop, as I work Monday through Friday 8-4.
EDIT: I saw the timing belt kit above (
http://shopping.boraparts.com/product_info.php?cPath=21_26_31_41&products_id=30) and was wondering what I should order. It looks like when you are selecting the stuff to buy, you can "add" options to the kit for improvements. Additions include the camshaft and lifter kit for and additional $168, a Dayco Belt for +$10, extra coolant for up for 3L or 4.5L, an EGR O-Ring for $3.50, an Idler Pulley (good for 150K-200K miles) for $24.95 and a serpentine belt tensioner (good for 150K-200K miles) for an additional $90. Would all of these upgrades be advised or do I just need the basic kit? I don't think I would need the camshaft and lifters given the relatively few miles on the car.
