BRADFORDKO
My 2004 Golf TDI (BEW) engine code recently began making sounds at idle, especially when AC is turned on or when stopped and turning the steering wheel. There is also a slight whistle sound sound at around 2,000 rpm while driving but that may be unrelated. I suspect the Alternator Clutch Pulley. I noticed the belt tensioner moving erratically the other day. I took a video which can be viewed at this link:
http://youtu.be/mbsmoEP3eT4
Also, I took the belt off and test the Alternator Clutch by locking the alternator with a screw driver and then seeing if the alternator pulley turned freely Counter Clockwise and locked clockwise. It is seized both ways, does not spin freely either direction.
This video I found at 2min 12 seconds discusses what my alternator pulley is doing which is seized when locked does not spin freely counter clockwise.
http://www.youtube.com/watch?v=fyosuYbPxr4
So does that mean I need to replace my Alternator clutch pulley. I have read up about a Metalnerd tool that makes it easier to remove or I plan to see if this tool can be borrowed from parts store.
Is it true that the alternator pulley on all A4-and-later TDIs are supposed to be a one-way (so-called "clutched") unit that turns the alternator when turned clockwise, and lets the alternator "slip" ahead when turned counter-clockwise? Since mine is seized and is locked when turning in both directions, that causes the belt tensioner to bounce around like crazy.
Is this a definite Alternator pulley replacement and a possible belt tensioner replacement?
Any advice would be appreciated.
Ken Bradford
2004 Golf TDI (BEW)
Plattsmouth, NE
Ken Bradford
2004 Golf TDI (BEW)
Plattsmouth, NE
