TDI Kovács
First off, I thought these alternators were pretty robust and rarely fail this early from what I've read.
Info: 2014 VW Jetta Sportwagen DSG 32,500mi. (Not a buyback. Has never sat more than a few days at a time.)
It started on my way home, the battery light came on.
After getting home I checked the voltage and there was no charge, showing right around 12V.
The next day I started the car and after a minute idling in the driveway, the battery light came on.
I hooked up VCDS and it confirmed no charge unless I had the RPM above 2000.
Now, a few days later, the battery light stays on no matter what the RPM is.
I checked the alternator pulley and it rotates smoothly counterclockwise and locks up in the clockwise direction. So that seems fine.
Inside the engine bay looks brand new. No leaks or wet spots anywhere. I even moved the fuel filter out of the way to look and the alternator looks brand new. It is the original alternator. So, nothing leaked into it.
I checked all the wiring and nothing appears to be loose or corroded.
I'm stumped!
Do I really need a new alternator or could it be something else I can check before spending so much?
Any help is MUCH appreciated.
I'm stumped!
