The spacers were from novustech. Very good quality, excellent customer service (and made in Canada!!). I got fully reimbursed once I explaind my problem.
I also bought from Novustech (first set), the 8mm didn't have the hubcentric lip, sold them, the 12mm, they wouldn't sit flush against the hub, contacted Ian, and he told me I'm out of luck, I should have read the disclaimer (
NOTE2: For some models, in order to correctly seat the spacer against the rotor, the hub might have to be machined or filled down until the back of the spacer sits flat against the rotor. , or something like that.... Whaaaat??) Sold them!
Bought all the replacement spacers from H&R. A bit pricier but NO PROBLEMS.
Got them from
www.rpiequipped.com, great people, great customer support. Tom J is the guy that looked after me. Great service and prompt replies to my questions. For US people, with the stronger US $, it may work out good too.
Spacers from 10mm up are hubcentric.
My H&R 8mm are hubcentric (with lip), and 150mm diameter.
Most places, you cannot buy spacers with less than 10mm that have the hubcentric lip.
NOTE1: spacers that are under 10mm will have no lip as it is not possible to put one on
They claim it cannot be done. H&R can (8mm only).
btw, CB must be 57.1mm, and if using OEM wheels, extended ball seat lugs nuts are needed
Do your homework!!
