50harleyrider
- Joined
- Jun 16, 2007
- Location
- charleston,wv
- TDI
- 2005 B5.5 TDI/geared BSM, BV43A turbo,stage 2 TDTUNING. 2005 5sp manual passat tdi stage 2 tdtuning,BSM delete. 2015 Passat TDI 6sp manual.
Can the tandem pump fail only on the vacuum side? I have a loss of vacuum, a hard ticking sound and a lot of oil around the rubber vacuum brake boost connector located in the firewall near the battery. That connecter is so gooey it has swelled to the point of no seal thus hard, crappy brakes. There is no other oil anywhere near the rubber block. It must be an internal seal issue with the pump. The engine runs perfect and no fault codes. The cam lobes all look great too including the small one in the back.Yet the ticking is rather loud. I need to pinpoint that noise source and would like some advice. My next move is to remove the pump and inspect it and it's slotted driver on the end of the cam
