jimbote
Certified Volkswagen Nut
four cylinder or V6? ....something doesn't look right....the VW pattern is small like the ford....where did you get the measurements for the TDI flywheel bolt circle?
I know the V6 ranger flywheel bolts are 10x1 just like the VW ...not sure about the 4 cylinder...they may be 7/16?So did you redrill the vw pattern between the ford pattern or did you reuse some of the holes? I don't know how you would do the latter as the ford bolt holes are probably 2mm bigger. tia
Looks like the v6.four cylinder or V6? ....something doesn't look right....the VW pattern is small like the ford....where did you get the measurements for the TDI flywheel bolt circle?
Not sure. Have both a vw flex plate and a 2.3L flywheel at work and will be measuring bolt patterns, etc.I know the V6 ranger flywheel bolts are 10x1 just like the VW ...not sure about the 4 cylinder...they may be 7/16?
Yes I surely am, but sadly the original motor the one with a mil plus lost oil pressure. So I put a new bullet in it in April and its back to hauling paper!are you still driving this truck?
I'm not sure of we might hear from this user last seen In 2019.... 3 years ago. Sending this user a PM or Email might actually yield results.How's the truck going @Lone Ranger?
Yeah, hoping it'll send him an email by me responding and bumping this thread.I'm not sure of we might hear from this user last seen In 2019.... 3 years ago. Sending this user a PM or Email might actually yield results.
And I can confirm the trans can't hold stage 4 torqueNo, I'm not driving that truck anymore. I built another one, my 3rd. The second one went to 1.35 million(altho not with the original ALH). After 7 years in our winters with these roads the body was done. So in may of 2020 I put another one on the road.
Its using the ECU from my last one with a stage 2 and a set of DLC 520s.
I reread some of this post and I should mention that the 2.3L clutch holds the 155ft/lb ALH. It does not hold the malone stage 2, 230ft/lb haha. So the only real difference between them all is the new one has the clutch/flywheel/pressure plate and starter from a 4L ranger
haha stage 4! Whats that like 280ft/lbs? So what did it do to it? And was it the R1 or R2 M5ODAnd I can confirm the trans can't hold stage 4 torque
Why not just go with a Tremec T5 and never worry about the trans breaking ever again? If you've got that much power a T5 with V6 or V8 gear ratios shouldn't be an issue. I'm considering swapping the 5sp out of my 87 Ranger for T5 to make my build easier.Is there anything you can do to make one of those M5OD's a bit stronger? I am looking at getting a old ranger to put my ALH in as the MK4 body is a bit rusty and it is just in the drive waiting for something to be put into
