subdvr99
Last weekend, I performed my 40K service, with no issues. The car ran fine all week, no inidcations of problems, although I did not check the oil level during the week after the day of the service. Today, I drove to the beach and back (about 1.5 hours round trip). After I got back in the car to run an errand, I pulled back and noticed a large pool of oil inder the car. I checked the oil, and it was very low.
I pulled the car into the garage and onto my ramps. I unbolted the belly pan, which was covered in oil. There was oil all over the underside of the engine, but no inidication of damage. I cleaned it up the best I could, added about 1.25L that I had left over from last week, and started it back up to look for the leak. It was clearly coming from the oil filter cap, about an inch worth of the circumference. And it was definitely more than a trickle.
As karma would have it, I don't have the 32mm socket to pull the oil filter cap (I usually do my service at the auto hobby shop on base). So, I'll buy one tomorrow, and check the condition of the O-ring/gasket, and the cap. Of course, I'll either have to go the VW dealer on Monday for a new one, or order one from TDIparts (unless they are available from the auto store?).
Ok, questions.
1) Why would the oil filter cap/gasket all of the sudden start leaking? I saw no oil at all this week, and then all of the sudden a whole bunch.
2) Should I first just re-torque it and start it up to see if it still leaks?
3) If I pull the filter, am I required to replace the gasket? Or can I reuse it since it is only a week old?
4) Any recommendations on oil I could get at Autozone or Advance, or should I wait for an order from TDIparts (my usual source)?
I'm pretty pissed. Hopefully, this is just something simple, but this is really the first issue I've had with my TDI. Bursts my bubble.
--Mark
Ok, questions.
--Mark
