Franko6
Vendor , w/Business number
Alex Wogamott (MOjetta)and I were putting a timing belt back onto an ALH engine. One of the last functions is tightening the 12 x 1.5 x 70 bolts that hold the body and engine mount together. The front one strips. UGH!
Normally, that means removing the body mount, jacking the engine up and down to get the three engine mounting bolts out, replacing the engine mount ($120) and the engine mount bolts ($20). There is also a long wait while you get parts when you should be driving down the road.
Here is the fix:
First, make sure that the stripped engine mount hole is evenly spaced inside the body mount, like this. The other engine mount bolt will hold the two mounts together for the procedure.(click on pics to enlarge):
Drill out the existing hole with a 31/64" drill bit. Be careful and go slowly. Expect the drill bit to be grabby. Drill till you bottom the drill in the existing hole.
Now, here is the trick.. The tap ALMOST fits into the motor mount. The tap is a special Recoil four-flute tap, which can fit inside the motor mount. A 3/8" extension can be used to drive the tap and get the tap handle high enough to get it clear of the motor.
Work the tap onto the top of the hole in the engine mount, square it up and work carefully until the BODY MOUNT has been tapped. You'll have a few threads on each side of the engine mount. Drive the tap into the damaged hole. Use grease or tapping fluid.
Get out the Recoil threading tool and a Recoil insert. The insert will follow the threads that are in the body mount. Note that the tang is down. Also, note that I have previously covered the timing belt with a shop towel to keep chips and debris out of the belt.
Drive the Recoil threads in with the special driver until the threads are about one complete thread inside of the engine mount. Break off the tang and remove the tang.
Clean up the area. Reuse the same bolt you just had used to strip that engine mount hole. Just make sure that the bolt threads are clean of aluminum.
I use 70 Ft. Lbs. torque for the large engine mounting bolts.
The whole repair process takes about 15-30 minutes and saves about $140 and days of wait.
I have the 12 x 1.5mm recoil kits in stock.
Here is the fix:
