Delvac 1 locator
BleachedBora
Vendor , w/Business number
Gresham, Oregon
'81 DMC-12, '15 GL350 CDI 275 hp/448 tq - '81 Caddy CJAA, '05 E320 CDI 250hp/450 tq, '23 ID4 AWD Pro S Plus
I've said this a couple of times already, but I will say it again. I used to buy Delvac-1 from Flying J--but they wanted $33-36 a gallon. I then found distributors that sold it for ~$22 a gallon--usually only if you buy by the case. Follow this link to find a distributor near you.
GoGolfing
Forsyth County, Georgia USA
Golf 2000 Candy White
Unfortunately, the 1st link is old and needs updating by Mobil.
According to this list on the 1st POST HERE: a Unocal 76 in Ontario, CA has Mobil Delvac 1.
When you call them a different story imerges: they told me: WE DO NOT STOCK MOBIL OIL! We're Unocal 76....
MilenP
Burr Ridge, IL
Sorry guys, just found the link. Did not call all the stores to check about prices /images/graemlins/grin.gif and if they still are selling Delvac 1.
Also, in Wisconsin, there is one more delaer for sure who does sell Delvac 1 and it's ~$20/gallon.
Jerry Willcomm
Mobil Oil
262 859-2831
GoGolfing
North of L.A. is a guy I called and has 50 cases on hand:
TOPANGA OIL 15372 COBALT STREET
SYLMAR, CA
(818) 364-9466
that's about 85 miles from me and I don't want to drive that far! But if you live nearby - there you go!
TornadoRed
West Des Moines (formerly St Paul)
2003 Jetta TDI wagon, silver; 2003 Jetta TDI wagon, indigo blue; 2003 Golf GL 5-spd, red (PARTED); 2003 Golf GLS 5-spd, indigo blue (SOLD); 2003 Jetta TDI wagon, Candy White (SOLD)
This is old news, but Mobil 1 5W40 Truck & SUV motor oil is repackaged Delvac-1. Now available at Kragen's motor parts in California, Schuck's in Oregon, and soon at auto parts stores in your neighborhood. $4.95/quart.
So no reason to ever pay more than $20/gallon for Delvac-1 synthetic.
tjl
California, USA
2001 Golf GLS
Now it appears that any Kragen, Schucks, or Checker auto store has Mobil Delvac 1 in quarts for $4.99, labeled Mobil 1 Truck and SUV.
TDI Nut
Ontario, California
01 Golf, 99 Beetle
Here is a link with info on this oil.
web page
[ QUOTE ]
[/ QUOTE ]
Cincy_Mike
Cincinnati, Ohio
Auto 2003 Jetta GLS TDI - Galactic Blue
I'm leery about buying repackaged oil and hoping it's delvac 1. I guess I'm a little unconvinced that you can buy it under a different name and pay less. Yes, I've heard you can buy it from Caterpiller and now as this Truck & SUV stuff. How are we so sure?
Of course, I'm quite new to this diesel game /images/graemlins/wink.gif
GoGolfing
So. California Delvac available @ Janovitch/Long Beach
Mobil 1 Delvac available (still:D)
Address:
14066 Garfield Avenue (north of 91 fwy or south of the 105)
(800) 650-0200
:D:D:D
GoGolfing
Mobil Delvac 1 DOES NOT MEET VW 505.01 spec
I had a conversation with Mobil Tech Rep today and he insisted that Mobil Delvac 1 *does not* meet the VW 505.01 spec.
I've been using this stuff since I bought my 2000 TDi Golf new in June of 2000: many on this site recommended it and I made my decision to use it.
I lost the turbo at 113,000 miles which is a shortened life for a turbo.
I'm changing to an oil that meets the 505.01 spec ===> That turbo was REALLY EXPENSIVE!!!
dieseldorf
MA
ex- 1996 wagon, ex-2000 Jetta
Does your 2000 Golf TDI require 505.01 :confused:
Dimitri16V
DE
01 Golf, 04 Golf
Maybe you need to talk to the PD owners that lost camshafts to 505.01.
I know somebody who lost 2 turbos in his PD in 150k miles using 505.01.
What's your point ?
Bob_Fout
Oil Wanker
Indiana
2003 Jetta - Alaska Green (sold) / 2015 GTI 2.0T
GoGolfing, there are folks with 300K+ miles with Delvac 1 on VEs, I suspect it was something other than the oil that caused the turbo failure.
Who diagnosed that your turbo was bad?
TornadoRed
Turbos fail, sometimes, and sometimes they fail because the oil feed line to the turbo leaked and the turbo didn't get enough oil. But no turbo ever failed because it was lubricated with Mobil Delvac 1 5w40. Sometimes they fail because of dirty intake air, sometimes they fail because of overboosting, sometimes they get replaced by dealerships even when the turbo is perfectly fine. I suppose the use of a conventional 15w40 might cause premature failure, but lots of turbos seem to last a long time even when that oil is used.
Your Mobil rep was right -- Delvac doesn't meet VW505.01 and it doesn't need to. No one ever said it did, and no one ever said your 2000 MY TDI required a VW505.01-spec oil.
GoGolfing
A4 requires 505.00 per VW owners manual
When I originally bought my 2000 VW Golf TDi in June 2000 - I joined Fred's TDI page and Mobil Delvac was one of the most recommended oils...
I did lose my turbo at 113K and it cost me mucho dinero$$$ even avoiding VW Stealerships (I did give them a shot at my business to which they all replied "We'll charge you $1800 for the turbo even if you have service done on the premises"
I've been looking for a decent and available substitute oil for a while.
dieseldorf
MA
Your turbo failure and your lube oil selection are unrelated.
Who said Delvac meets any VAG spec :confused:
Bob_Fout
Oil Wanker
Indiana
GoGolfing, and on the same note that Mr. Dorf brought up, VEs don't require VAG 505.01, VAG 505.00 (per VWoA) or any VAG spec oil. Nor does Delvac 1 meet any VAG specs, just API and various engine-specific specs.
K5ING has 400K miles using mostly Delvac 1 in his VE TDI.
GoGolfing
Concession?
I concede that I cannot directly and conclusively "blame" my turbo failure on Delvac I (rated for compression ignition engines) - I still maintain it's a good product but now it is unavailable from Mobil.
I'm going to start reading posts on which is the best oil to run my 2000 VW Tdi and hopefully find something that is somewhat "available".
Also- when my turbo blew - I had the intake cleaned and it was fairly nasty but not the worst I'd ever seen. I'm going to perform an "ectomy" and prevent the intake from taking all this crap down it's throat. What a regrettable design...
TornadoRed
CarQuest and NAPA can order Mobil 1 5w40 for next-day delivery to the store, if they do not have it in stock. O'Reilly's may carry it, I haven't been in to check. AutoZone is a crapshoot.
