Kerma_tuned
Been a while since ive posted.
My 02 alh jetta that i have put a 3inch exhaust, vnt17plus turbo, egr delete, 2" intercooler plumbing, kerma upgraded intercooler, and r520's, and kerma custom tuning is soon getting swapped out. The engine only has 235xxxkm's....
However everything is getting moved over to another alh engine at 207xxxkm's thats in enginetech's machine shop.
Soooo im almost out of ideas....
All said and done the engine will have:
-vnt 17plus turbo
-r520 injectors
-3" turboback exhaust
- 2" intercooler plumbing
-kerma smic
-egr delete
-integrated engineering rods
-11mm fuel pump
-Colt stage 3 camshaft
-port and polish
-bored out to the next size
-forged pistons/crank(maybe? Will it need them?)
Current crank is out by 3 thou
Bore was out by 2thou
The valves are good it just need valve guides
Its getting a timing belt kit, all seals/gaskets are
Being redone. Sooo to my questions now.....what numbers can one expect? Any steps or limits to put in place to avoid destroying this engine? What can i do to push the limits more? All opinions appreciated??
-vnt 17plus turbo
-r520 injectors
-kerma smic
-egr delete
-11mm fuel pump
-port and polish
