MAXRPM
Mk4 golf alh racer,,, giving me these codes and headaches, NO EGR so this code is not a factor, a good N75 swapped from my jetta and still does not work with my golf,,,erase all codes and they come back.
Fault Codes have been Erased
3 Faults Found:
01269 - Commencement of Injection Valve (N108)
31-10 - Open or Short to Ground - Intermittent
01265 - Exhaust Gas Recirculation Valve (N18)
31-00 - Open or Short to Ground
01262 - Solenoid Valve for Boost Pressure Control (N75)
Readiness: N/A
No boost on turbo, actuator not moving, timing with vag.com stuck at 255, sent IP to DFIS Portland and they shipped it back to me saying solenoid was good,,, golf fires whenever she wants in the morning any help would be appreciated
go TDI
3 Faults Found:
Readiness: N/A
go TDI
