What did you do to your MK7 today?
jason_
michigan
2015 s wagon dsg
Mounted some new summer 16s.
I was going to balance them, but this time I'm trying the steel shot trick....
I put 10oz in each tire. See what happens.
Sent from my 2PS64 using Tapatalk
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
Forget that trick, it will not do anything but really screw up balance.
thundershorts
west chester pa
If you've ever gotten water in a tire you will know what I mean.
Discovery
Montréal
Mk7 SportWagen
Airlift bag in a H&R spring. Pretty sure I'm the first one to do that.
Now it sit the same with or without trailer.
Discovery
Montréal
Mk7 SportWagen
Got a part/model number on that airbag lift?
This is the airlift 80753, it is perfect for stock height spring.
But, if I was to do it again I would use the airlift 80777 which is 1,75 inch shorter.
Because I'm running lower than stock (H&R) spring, I ended up not using the supplied "spacer/protector" in order for them to fit in.
Time will tell if its going to affect their durability.
740GLE
NH
I've heard they need a minimum PSI otherwise they'll develop a tear along the body of them, keep an eye on them.
How are you routing the filling port/valve? I've been toying with the idea of placing mine by the fuel filler door.
Discovery
Montréal
Mk7 SportWagen
Yeah, I heard that... Pretty much impossible to remove them without damaging the bag. If/when they fail I'll install the shorter kit.
Valve are under the bumper, pretty much invisible without kneeling.
ProfBrown
So Cal
2015 GSW SE DSG
This above looks really clean man. Nice! If I have the need to put a hitch on mine I’ll do this for sure for the trailer lights.
740GLE
NH
whoa, you went with two valves and not a T so each bag are even? you going to fine tune each bag depending if there is a passenger or not?
very nice install, did you have to pull the bumper cover off to mount those?
Discovery
Montréal
Mk7 SportWagen
No removal needed.
It's not really for fine tuning, it's to find out quickly which one is leaking!
Nuje
Island near Vancouver
2015 Sportwagen; Golf GLS 2002 (swap from 2L gas); 2016 A3 e-tron
No removal needed? So, you can just reach into the centre cavity and route the air lines from there (?).
Or do you just mean that the bottom valance comes off separately / cleanly?
Nuje
Driving home the other night (clear, perfect summer evening), suddenly I get a warning message that "FRONT ASSIST SENSOR BLOCKED"
Only ever seen this before in the winter when snow/slush builds up on it.
Get home and...
[Insert Batmobile joke here] :D
Discovery
Montréal
Mk7 SportWagen
Get home and...
His radar was defective too
justin71105
SC
2005 Jetta Wagon (BEW)
Wash and some Simoniz ceramic wax today.
Still have a lot of swirls I need to work on but that will be later this year before I start that.
Discovery
Montréal
Mk7 SportWagen
Replaced the original battery with a Kirkland group 48 yesterday.
Use this plug made by noco specifically designed to prevent computer reset while doing battery replacement.
Didn't work, and it shorted my obd fuse.
Managed to enter new battery value with obdeleven and reset "most" of all the alarm, the few left resetted themselves within few minute of driving.
Over all I shouldn't have used this fancy ecu saver cable and went the way I always did, alligator clip the battery cable on the new battery while replacing.
goes2fast
Colorado
2015 GolfS, GTI 18s, H&R springs, Stage 2
Found a moment to take a quick picture.
That almost looks like stock compared to mine, I have 20%, because I'm older I think the cops leave me alone. I had it on both my MK7s and the wife's Jetta with no problems from the police and have driven on 2 cross country vacation trips. One to Florida and one to Vancouver BC.
And my pickup as well.
goes2fast
Colorado
If that car had a GTD grill I would say it was my old one that I turned in for more than I paid for it. :)
Anyone need a Flashzilla? Since I no longer have a TDI I don't need it. It was only used twice once to load the tune and again to remove when I turned my car in.
740GLE
NH
someone will buy it, they hold their value pretty good, i'd say $150 shipped should disappear within a week.
Nuje
I installed the AirLift 80753 air bags on my rear springs today. Contrary to lots of other people's experience, getting the bags into the springs wasn't too difficult - less than half an hour for both of them.
Just squeeze all the air out, fold it best you can lengthwise (so it's like a hot-dog bun), then cram it through one of the lower spring gaps. First half doesn't take much effort - just guide/pull the top a bit as your push from below; then once it gets stuck, start twisting it so that it screws itself up/in. Use a piece of wood to pop in the last bottom corner(s).
740GLE
NH
you go with valve up or down on the install?
Nuje
Valve down, fed the air line out through the bottom of the spring perch, across the rear beam, under the protective covers of the tanks and spare tire well, put the T just before I got to the bottom of the bumper cover, then put the schrader valve coming out the RH side of the little cut-out in the bottom trim piece.
740GLE
NH
i ran the hose down as well.
I kinda wished i tried longer at the deflate squeeze method but i gave up and dropped swing arms.
I do have a small squeak going over bumps that has developed with about 10-12psi in the bags.
Discovery
Montréal
Mk7 SportWagen
First "long distance" 2h I did with the airlift bag installed in h&r spring.
Really happy, everything is now level. Ride is also dramatically improved, no more bouncing.
