Btdi
Today I bought a TDI parts/donor car and I will be beginning the manual swap from this 2000 tdi to my 2005 Mkiv tdi. I was wondering which is better for this swap a single mass or dual mass flywheel?
Well put!!If you plan on keeping power levels within 15% of stock, then the DMF is the better choice.
If you plan on modding for mroe than 15% stock power, then go SMF with a high torque yield rating.
I would go so far as to agree with slamhouse but would add that if you want a clutch that performs like some of the best clutches you have ever driven, then go with a SMF clutch. If you want a clutch that has a vague engagement point and is a chore to drive, go with a DMF clutch.If you plan on keeping power levels within 15% of stock, then the DMF is the better choice.
It shouldn't be to bad, worst-case I Know an engineer knows about the wiring.FYI the wiring sucks for the PD swap.
The DMF in my jetta engages perfectly and better than any other clutch ive driven which is partly why i bought it.I would go so far as to agree with slamhouse but would add that if you want a clutch that performs like some of the best clutches you have ever driven, then go with a SMF clutch. If you want a clutch that has a vague engagement point and is a chore to drive, go with a DMF clutch.
I suppose some years are different, but my 2006 A5 DMF clutch would bring tears to your eyes because of how miserable it was. I went from stalling the car about 5 or more times a week to stalling it about once every 6 months.
Of course my experience is only with 1 clutch so maybe I just got a "dud". My DMF was always about the same from brand new. With less than 20 miles on it, during the test drive I stalled it several times.The DMF in my jetta engages perfectly and better than any other clutch ive driven which is partly why i bought it.
Perhaps your clutch developed a glaze resulting in harsh engagement.
The only bother i have with the DMF is the pulsating clutch pedal byt ive come to accept it.
I need to switch it out due to the excessive noise of it getting ready to explode, it's pretty loud once it gets heated up. when the car is cold it doesnt really make the slapping sound, but while driving/in neutral you can hear the throwout bearing squeaking too not bad but enough to warrant replacement. I plan on getting the sbc stage 2 daily. SMF with clutch. at least i think that is what is wrong with the car. I'm not a mechanic however.I know I did not like the original DMF in my 01 bug, however, the DMF I have with the 02M (Sachs) is a dream to drive. Have done 3 of these and they are perfectly consistent. I have no experience with the SMF, however, personally if I were dealing with the 5 speed, I'd go the silent design SMF by southbend.
