• The TDIClub classifieds section is a heavily trafficked section of the forum that encompasses want-to-buy (WTB) and for-sale (FS) threads for the entire world. Due to the demanding nature and fast pace of this section, it is imperative that you know and understand the rules. It is also important to remember that this is the only parts classifieds section.
    Cross-posting and posting classifieds in the regional sections (except the dedicated thread in Ontario) is not permitted.
    Multiple items should be sold in one thread. Make sure to provide a description for all items in your post along with pictures and prices. If you start multiple threads with individual items, they will be locked or combined at the discretion of the moderators.
    Here is a quick outline of the classifieds section rules. If you don't follow these rules, you subject yourself to thread deletion, thread combination, infractions, or posting privilege revocation.
    Thread titles:
    • Put FS or WTB in your thread title. This will let other users know if you are selling or buying.
    • Briefly describe what you are selling. Thread titles have limited space. Be as descriptive, yet succinct, as possible.
    • Put your location in the title.
    • If space allows, put your price in the title
    Title example (single item): "FS: 2004 Mk4/BEW cylinder head - Portland, OR - $500"
    Title example (multiple items): "FS: MK6 fog lights, front bumper, headlights, grill - Detroit, MI"
    Title example (car part-out): "FS: Mk3 Jetta parting out engine & interior - Dallas, TX"
    Thread text descriptions and pictures:
    • All for-sale threads must include pictures of the items that you are selling. One picture is sufficient, but multiple pictures with different angles will help buyers. A picture is worth a thousand words. If you don't know how to post pictures on TDIClub, see this thread: http://forums.tdiclub.com/showthread.php?t=286691
    • All for-sale threads must include a description. We don't charge per-word, so be as descriptive as possible. The more information you can provide, the easier it will be for buyers.
    • All for-sale threads must include a price. Auctions and bidding are not allowed. If you want to auction something off, use eBay.
    No picture, no price, NO SALE!
    Thread maintenance/updates/bumps:
    • When you sell something, update your thread with "SOLD!" Moderators will close the thread and update the title.
    • If you have multiple items for sale, update your thread as each item has been sold. When everything has been sold, updated the thread with "ALL ITEMS SOLD!" Moderators will close the thread and update the title when all items have been sold.
    • If you bump your thread, please delete old bumps by clicking on EDIT and then deleting the old bump. This will reduce clutter in your thread and make it easier to read. It also makes you look less desperate.
    • If you drop your price, please update your first post in addition to posting the new price. If you would like the thread title changed, click on the report post icon and let a moderator know what you would like the title changed to.
    Moderator intervention and infraction points:
    Moderators will be monitoring the classifieds section. If a moderator determines that you have not been following the rules listed above, corrections will be made and infraction points will be assessed to your account.
    What is an infraction point? Simple - it's a system of keeping track of user behavior. A moderator can assign a point value based on the severity of the infraction, as well as an expiration date on the points assessed. If you accumulate a certain number of points, the system will auto-ban you for a predefined amount of time. The more points you accumulate, the longer your ban period will be.
    One example of points is as follows: multiple threads will be combined into a single thread, with the number of infraction points assessed corresponding to the number of threads merged. If we merge four threads into one, then you will be assessed four points that expire in 30 days. When you reach five points, the system will auto-ban you for one day.*
    *This is an example based on the current infraction system structure. We reserve the right to modify the infraction system at any time without notice or updates to this announcement.
    Thank you for your cooperation, and good luck with your sales and searches! :)
    -TDIClub Administration
WTB: A3 (1998 Jetta) N108 Advance Solenoid
sonar23
Saratoga, NY
1998 Jetta Black, 2005 Jetta TDI Wagon
I'm looking to buy a used or new N108 IP Advance Solenoid. This is the part that mounts on the bottom of the injection pump. I have the classic symptoms and believe this will solve my issue.
Thanks,
Devin
jimbote
Certified Volkswagen Nut
Tacoma 4x4 converted to TDI
Hi Devon....not sure your status as far as pump removal but I was able to repair the N108 on a 98 AHU....the wires had broken where the drive belt tensionor had rubbed them....have you checked the wires?....
sonar23
Saratoga, NY
Thanks. I will take a look. I have not checked the wires. This certainly could be the issue.
Thanks,
Devin
sonar23
Saratoga, NY
I took a look this morning at the wires and connector. They appear to be OK.
Thanks,
Devin
sonar23
Saratoga, NY
I did not. I'm not familiar with this valve. Can you provide more information?
Also, this afternoon I took another look at wire leading to N108. One of the wire did have a nick on it and there was evidence of oxidation. I cut and re-spliced, but car behaves the same. This could be because injection timing is still way off (it was reading 255 - off chart). I need to run VAG-COM again to see if injection timing is on the scale.
BTW, since I had cut one of the wires to the N108 solenoid, I decided to see if the car would run OK with the wire disconnected. It started fine, but immediately went into limp mode. The car was warm when I started it.
Finally, I tested the resistance of the solenoid N108 and it read 17.5 ohms. I haven't seen any posts that indicate a normal resistance for the N108. I expected that it might be an open circuit and I could conclusively say it is bad.
greenskeeper
USA
1998 Jetta TDI
the valve is on the top of the IP near the fuel cutoff solenoid. You can remove it with a 10mm wrench if you are good. The guts of the valve may come apart and not allow proper timing advance. Simply put the guts back together and you're good to go (hopefully!)
sonar23
Saratoga, NY
I'll take a look at the valve. Since I posted this afternoon. I have found some posts that suggest my resistance reading should be OK for the N108 solenoid. I wonder, though, if something could be clogging the screen on the solenoid. Therefore, it may appear to function properly based upon resistance, but actually not.
Thanks,
Devin
