Old December 8th, 2018, 14:18   #1
Jsstr8
Default mTDI boost controller
Iím building an mTDI to put into my Ď82 Westy Vanagon. Iím in the final stages after years of blood, sweat, and tears (and lots of money). However I am new to turbos and want to make sure that I plumb mine in the appropriate manner. I have read, but cannot find a definitive answer anywhere.
My GT2052 is currently plumbed from the housing side to the wastegate. I have read that many people put a manual boost gauge in between this connection. I have also read that it is better the plumb the wastegate off the intake manifold (especially if you are using an intercooler which I am). My IP also has a pressure nipple on it. Iím assuming to increase fuel in line with increased air.
Taking all this into account, I think I need to run a line off the intake manifold to a manual boost controller. From the boost controller, I need to tee the fitting running one hose to the wastegate and the other to the IP. Is this correct?
I may also want to run a boost gauge. Can I hook this up to the turbine side of the turbo that I am no longer using or do I need to plug that connection and tee of the boost controller 3 times?
Sorry if this is in the wrong place, but this seemed like the most appropriate area. Please move if I was incorrect.
Jsstr8 is offline   Reply With Quote
Old December 9th, 2018, 12:22   #2
CasaEd
TDI(s): VW Passat B4
If i was doing this I would connect the boost controller between the turbo housing and wastegate and the boost gauge between the inlet manifold and top of the injector pump using a T piece, it keeps it simple
CasaEd is offline   Reply With Quote
Forge boost controller for limiting boost levels? GTiTDi TDI Power Enhancements 3 December 13th, 2011 18:24
my boost controller screeches at 17psi of boost and above 85_305 TDI Power Enhancements 41 July 21st, 2011 08:06
MTDI Conversion vacuum and boost? tcxtreme TDI Conversions 6 May 13th, 2011 22:13
Boost Valve/Boost controller what to Buy ? volks_r_us TDI Power Enhancements 11 September 8th, 2006 21:18
TurboSmart "Boost Tee" manual boost controller 03_01_TDI TDI Power Enhancements 6 August 14th, 2004 19:50
Page generated in 0.13758 seconds with 12 queries
[Output: 52.52 Kb. compressed to 48.62 Kb. by saving 3.90 Kb. (7.42%)]
